Want to build a sturdy, flat-pack-style piece of furniture like the ones from big-name shops? Then the cam and dowel (barrel nut) system is just what you need! In this step-by-step guide, we’ll show you how this type of assembly works, how to drill the right holes, and how to put everything together accurately. With a bit of care and the right tools, you can achieve a professional-looking result right at home.
Here I am again................. :D
Since I was asked to create a detachable white laminated plywood bathroom cabinet, what better choice than using the famous pin and barrel joints, which are commonly used in most detachable particle board furniture? The problem is, I've never used them before, so I wanted to share with you the test I conducted using scrap pieces.
Contents of the Kit
Let's start by looking at what the kit includes and what each component is. From left to right, we have:
- A 10 mm sleeve
- A 10 mm barrel
- A 7 x 20 mm pin
- A 3 mm grub screw
Mounting the Pin
To begin, drill a 9 mm hole as shown in the photo on the base of the cabinet, 9 mm from the edge, with a depth of 11 mm. The hole must be smaller than the sleeve (which has a diameter of 10 mm), otherwise it will wobble inside.
Inserting the Sleeve
Next, we insert the sleeve into the hole, using a hammer to help, and then screw in the pin.
Drilling the Hole for the Pin Slot on the Back of the Other Piece
At this stage, we move on to drilling the back of the other side of the cabinet, again 9 mm from the edge, to a depth of 22 mm using a 7 mm drill bit. By wrapping a piece of tape (masking tape will work perfectly for this) around the drill bit at the correct measurement, you can easily tell when the hole has reached the desired depth.
Drilling the Hole to Insert the Barrel
Now we move on to the hole that will host the barrel, which must have a diameter of 10 mm and be drilled deep enough to reach the pin hole. The distance from the edge must be 21 mm, and we need to ensure it is perfectly aligned with the pin hole.
Inserting the Barrel
Now we insert the barrel, carefully aligning the notches with the previously marked line.
Assembling the Joint
We insert the side with the pin into the hole and screw the grub screw into the barrel.
We tighten the grub screw all the way until we feel the base pulling the side panel towards itself.
Conclusions
As shown in this photo, if the measurements have been followed correctly, the two pieces align perfectly flush, and the joint is both easily detachable and reliable, as the wood of the cabinet is never subjected to stress.
For those who wish to ask questions on this topic, feel free to join the discussion already active on the forum at the following link:
https://www.ilsitodelfaidate.it/FDTForum/viewtopic.php?t=6811
