You opened your wardrobe door and—snap! The hinge has come away from the cabinet side? Don’t worry, you don’t need a new wardrobe. In this guide, we’ll show you how to fix modern clip-on hinges when the mounting holes have become stripped or too loose to hold. With a few simple tricks and some basic materials you probably already have at home, you’ll have your door back in place in no time.
I hope these photos can sufficiently illustrate the steps to take in the classic case of a plastic base breaking on typical wardrobe hinges. No special tools or woodworking skills are needed, just a bit of good will.
In this photo, you can see what a base supporting the hinge looks like when it’s still intact.
What happens when the base breaks or detaches from the cabinet
Over time, the base of this type of hinge, which is fixed by pressing into pre-drilled holes in the chipboard, tends to detach, "fraying" and enlarging the holes. At this point, they can no longer guarantee a solid attachment.
If the base is secured with screws, the same issue occurs with the screw holes.
Closing the holes with wooden dowels
First, we insert two dowels of the appropriate diameter into the holes after carefully coating them with wood glue.
If the holes are too small (as in the case of screw holes), we can widen them with a drill using a suitable bit.
Cutting off the excess part
Once the glue has dried (at least 4 hours), we trim the dowels flush with the surface. Then, gently, we use a file first and then sandpaper to level everything smoothly with the wood.
Finishing
We fill and even out the surface with ready-made wood filler. You can use a filler that’s already coloured to match the wood tone of your wardrobe, or a white filler that can later be coloured with a touch-up wood marker.
Sanding
Once dry, we gently sand the surface using 320-grit sandpaper.
Attaching the new hinge
We secure the plate to the hinge, drilling new holes if necessary, and test the closure.
Then we secure the plate with two screws, and that’s it—job done.
Anyone with questions or curiosities, or simply wishing to let us know that this article has been helpful, can write on the forum (from which this article was sourced) at this link:
https://www.ilsitodelfaidate.it/FDTForum/viewtopic.php?t=6741
Thank You
