You know that electric grill you use almost every day—the one with two hot plates that’s perfect for toasting bread, making sandwiches, or even cooking meat and fish? Well, I’ve got one of those, and one day it decided to take a dive—crack! The handle snapped right off.
Instead of binning the whole thing, I rolled up my sleeves and set out to fix it myself. In this article, I’ll walk you through exactly what I did—from removing the broken bits to the materials I used to rebuild it.
If you’ve run into the same issue, stick around. With just a bit of effort, a few tools every DIY enthusiast has lying around, and hardly any cost, you can breathe new life into your broken appliance too.
Hello everyone,
The other day, we left our electric grill resting on top of the washing machine in the kitchen—and during the spin cycle, the washer decided it had enough and sent it crashing to the floor.
The result? As you can see in the photos, the two plastic supports that hold the top plate’s handle in place snapped clean off, making the grill pretty much unusable.
Fixing the Broken Handle with an Aluminium Bracket
This grill might’ve been a bargain (I paid no more than 25 euros for it), but it’s practical, has a generous cooking surface, and most importantly—it’s practically brand new. I’ve used it maybe ten times tops. So of course, the DIY spirit kicked in and I started thinking about how to bring it back to life.
The first idea that came to mind was to use some aluminium angle brackets. I figured I could attach them to the two broken stubs of the handle supports using aluminium rivets. That way, the pieces would be held firmly together and the brackets would give extra strength to the cracked joint.
Why That Solution Didn’t Work
Unfortunately, even though I added metal washers to stop the rivets from putting too much pressure on the holes in the plastic, the plastic itself just wasn’t up to the job. It cracked again—clearly not the toughest material—so I had to give up on trying to fix the original supports. In the end, they were beyond saving.
Rebuilding the Handle from Scratch
At this point, I decided to completely remake the two supports. I used a rectangular aluminium profile, 10x20 mm in size—something I already had lying around in my little workshop corner. But no worries if you don’t have one handy: you can easily find the same thing in any decent hardware store or DIY shop.
Cutting the Aluminium Brackets
So, I cut two pieces of aluminium to match the length of the original supports, then marked and drilled holes to line up with where the old plastic ones had been fixed.
Now, the original parts had an “S” shape, while my brackets are straight—but that’s not a big deal. It won’t affect how the grill works. The only visible difference is that the handle now sits a little higher than before.
First Fitting Test
At this stage, I did a first test by attaching the new supports to the grill—and... it looks like it works! I reused the original screws, and the only tweak I had to make was adding a few washers where the aluminium was thinner than the old plastic supports.
Spacers and Adapters
I also had to add spacers to the central screws (1), which I made from a round aluminium rod. On the right-hand support, I riveted on a small aluminium plate (2), which acts as a stop against the movable limiter (3). This limiter can be lowered to allow the grill to open up fully, with both plates lying flat.
Rebuilding the Handle in Wood
At this point, I grabbed an old wooden broom handle, sanded off the paint to get back to bare wood, and cut it to the right length. I pre-drilled holes for the screws and gave it a coat of wood stain I had left over from a previous project. Once mounted, it seemed to do the trick.
Testing It Out
I gave it a proper test run, and everything seems to be working just fine—the supports are solid and there’s no wobble, with a smooth, steady motion. I’d say (as long as I don’t drop it again!) this grill is ready to get back to work and keep going strong for a good while yet.
I hope this article has been interesting and helpful to someone out there. Thanks to everyone who took the time to read it—wishing you a great day! P.S. If you’ve got any questions, tips, or just want to let us know you enjoyed the article, feel free to leave a message on the forum where this post originally appeared by following this link:
Repair of grill with broken handle
Thank you all
