- When a Screw-Type Faucet or Tap Gets Stiff: Causes, Symptoms and When to Act
- Removing the Handle: How to Take Off the Cover Cap and Access the Retaining Screw
- Identifying the Faucet Body Components After Removing the Handle
- Removing the Chrome Collar: How to Unscrew It Without Scratching the Surface
- Unscrewing the Faucet Body Nut: Which Wrench to Use and a Handy Trick
- Opening the Faucet Body: Two Wrenches to Separate the Two Nuts
- Cleaning and Servicing the Mechanism: Stem, Threading, Grease and O-Ring
- Frequently Asked Questions About a Stiff or Seized Screw-Type Faucet or Tap
- Conclusions and Acknowledgements
IOver time and with daily use, a screw-type faucet or tap can gradually become harder to operate: turning the handle gets increasingly difficult, especially when closing, and often the only way to manage it is to rotate it back and forth several times with considerable force. The most common causes are limescale buildup around the stem and threading, deterioration of the washers and O-Ring, and lack of lubrication in the internal mechanism. In areas with particularly hard water, the problem can develop within just a few years. Before the faucet seizes up completely or gets permanently damaged, it is worth stepping in: disassembly, cleaning and lubrication are well within anyone's reach, requiring only basic tools and no need to replace the faucet entirely.
To begin the disassembly, start with the handle. This is held in place by a retaining screw that may be exposed or, as shown in the photo, hidden beneath a cover cap. Before proceeding, take a close look at the cap to determine how it is secured, as there are two different types: the most common is the push-fit cap, which is simply removed by gently prying it off with a flat-head screwdriver, being careful not to scratch the chrome surface. In some cases, however, the cap is threaded: this type is easily recognised by its knurled outer edge, designed specifically to be gripped with the fingers and unscrewed counter-clockwise without the need for any tools. In both cases, once the cap is removed the retaining screw will be fully accessible: unscrewing it allows the handle to slide off easily, leaving the brass faucet body exposed and ready for the next step.
Once the retaining screw is removed, the handle should slide off without difficulty. If it feels stuck, a few sprays of penetrating oil — such as WD-40 or a similar product — will make the job considerably easier. As shown in the photo, at this point the cover cap, the retaining screw and the handle itself will be lying on the surface, while the brass faucet body is now fully exposed with the threaded stem clearly visible at its centre. On the body you will notice two nuts of different sizes: the upper one, which is smaller and from which the control stem protrudes, is easily accessible but is not the one we need to remove. The nut to disassemble is the lower one, which however is still concealed by the chrome collar: before reaching it with a wrench, it will be necessary to remove the collar first.
With the handle removed, you can now proceed to unscrew the chrome collar that covers the base of the faucet. Simply grip it firmly with your hands and turn it counter-clockwise. If over time it has seized due to limescale buildup — as can be seen in the photo, where the brass body shows clear signs of mineral deposits and corrosion — it may be necessary to use a rubber strap wrench, which provides a firm grip without any risk of damaging the surface. Alternatively, an adjustable wrench works just as well, as long as the collar is protected with a piece of rubber inner tube or a thick cloth to prevent scratches. Once unscrewed, the collar slides upward and off, leaving the faucet body completely accessible and ready for the next step.
With the chrome collar removed, the faucet body is now fully accessible. As shown in the photo, the two brass nuts of different sizes are clearly visible: the upper one, which is smaller and from which the stem protrudes, and the lower one, which is larger and is the packing nut that needs to be unscrewed using a wrench of the correct size. Before proceeding, there is a small but very useful trick that can make the operation considerably easier: briefly refit the handle onto the stem and turn the faucet to the open position. This way the internal mechanism will not be under tension, and the nut will loosen much more easily without resistance.
To open the faucet body, two wrenches are needed at the same time: one holds the lower nut in place as a counter-hold, while the other — as shown in the photo, a 13 mm wrench — engages the upper nut to unscrew it. There is no risk of confusion: since the two nuts are of different sizes, each wrench will naturally fit only the correct nut. Once the upper nut is unscrewed, the faucet body opens up and the internal mechanism is finally accessible for inspection and servicing.
With the upper nut removed, the control stem can finally be extracted. Pay attention to one important detail: the threading is reverse, meaning that to unscrew and remove the stem you need to turn it clockwise — as if you were tightening a regular screw. As shown in the photo, once extracted the stem clearly reveals the threading and the O-Ring — the small black rubber seal that ensures a watertight fit. This is often the main cause of the problem: over time the O-Ring hardens, deforms or deteriorates, causing the mechanism to stiffen and become increasingly difficult to operate. The servicing procedure is straightforward:
- Thoroughly clean the stem and the inner seat of the faucet body, removing limescale, old grease residue and any other deposits
- Replace the O-Ring with a new one of the same size, easily available at any hardware store
- Lubricate the stem with faucet-specific grease before reinserting it
Reassemble all components in reverse order and the faucet will turn smoothly again, just like new.
Q: What are the main causes of a screw-type faucet becoming stiff? A: The most common causes are limescale buildup around the stem and threading, deterioration of the O-Ring which loses elasticity over time, and lack of lubrication in the internal mechanism. In areas with particularly hard water, the problem can develop within just a few years.
Q: Do I need to turn off the water before disassembling the faucet? A: Absolutely yes. Before starting any work it is essential to close the isolation valve on the water supply, which is generally located under the sink or near the main stopcock. Once closed, open the faucet you are about to repair to release any residual pressure remaining in the pipes.
Q: What tools do I need for this repair? A: Only a few basic tools are required: a flat-head screwdriver, two wrenches of different sizes (or an adjustable wrench), a rubber strap wrench for the chrome collar, and faucet-specific grease. For reassembly you will also need a new O-Ring of the correct size, easily available at any hardware store.
Q: How do I find the correct replacement O-Ring size? A: The easiest way is to take the old O-Ring directly to a hardware store and have a member of staff match it for you. Alternatively, you can measure the internal diameter and the cross-section thickness with a calliper. O-Rings for faucets and taps are standard components and are usually very inexpensive.
Q: After the repair, the faucet has started leaking again. What went wrong? A: If after reassembly the faucet drips or leaks, it is likely that the O-Ring was not replaced or is not the correct size, or that the seat washer — the small rubber disc at the tip of the stem — also needs replacing. In that case, it is worth consulting the companion guide on repairing a leaking screw-type faucet.
Q: How long does this repair take? A: With a basic level of DIY skill, the entire operation — disassembly, cleaning, O-Ring replacement and reassembly — can be completed in 20 to 30 minutes. Most of the time is spent cleaning the components, especially when heavy limescale deposits are present.
And here we are at the end of this guide: I hope the step-by-step instructions on how to disassemble, clean and lubricate a screw-type faucet have given you everything you need to tackle the problem on your own, without having to call a plumber for a repair that is well within anyone's reach.
If after completing the servicing the faucet is working correctly again but you have noticed it is dripping or leaking from the base, the problem is most likely related to the seat washer. In that case I recommend reading the companion guide: Fixing a Dripping Screw Faucet
If you would like to explore other DIY plumbing repairs, you can continue reading by visiting the other guides available in the Plumbing section of the site, where you will find many more practical step-by-step guides.
I care deeply about the quality and originality of the content I publish, and I would prefer it not to be copied or republished elsewhere. However, if you think this guide could be useful to others, I would be truly grateful if you could share the link to this page: it is the most respectful way to spread the information and support the work that goes into every article.
Happy DIY Repairs to Everyone
